OPCUA Node
The OPC Unified Architecture (UA), released in 2008, is a platform independent service-oriented architecture that integrates all the functionality of the individual OPC Classic specifications into one extensible framework.
OPCUAClient Node is a ROS2 node, it can be set to subscribe data form OPCUA server and provide ROS2 DDS topic for user to subscribe, user can quickly receive OPCUA data and do the post data process, for example data parse/store/analysis etc. Below chapter will introduce you about how to use OPCUAClient Node.
Topic Definition
The topic of OPCUA node data are defined as below:
/adv/opcuaclient
Message Definition
The messages definition is defined in below link:
Configuration
To config OPCUA node settings, please refer the guide: OPCUA Node Configuration Guide
Verify Sensor Data
The message is updated periodically, you can use ROS2 utility to verify the data update:
Step1. Setup ROS2 environmant variables:
$ source /opt/ros/${ROS_DISTRO}/setup.bash
Step2. Setup OPCUAClient Node message:
$ source /usr/local/Advantech/ros/${ROS_DISTRO}/include/edge-converter-ros2/adv_msgs/install/local_setup.bash
Step3. List all topics:
$ ros2 topic list
output:
/adv/parameter_events
/adv/opcuaclient
/parameter_events
/rosout
Step4. Echo node data
$ ros2 topic echo /adv/opcuaclient
output:
sensor: OPCUAClient/OPCUA-01/Node/Temperature
type: v
bv: false
v: 25.713000000426085
sv: ''
ts: 1677661555546
sensor: OPCUAClient/OPCUA-01/Node/Humidity
type: v
bv: false
v: 59.999999999653745
sv: ''
ts: 1677661556561
Run Sample Client
This session describe how to subscribe OPCUA node data using sample client.
Node.js
The program rclnodejs_edge_data_client is a node.js example for user to learning how to use rclnodejs client to subscribe OPCUA node's data. Please follow below steps to run the program, when the program launched, it will subscribe OPCUA node's sensor data and print the data in the console screen.
Subscribe Sensor
Step1. Setup ROS2 environmant variables, replace ROS_DISTRO with your ROS2 distribution (foxy, humble) to run this command:
Step2. Setup OPCUAClient NodeS message:
Step3. Go to node.js OPCUA sample path:
$ cd /usr/local/Advantech/ros/${ROS_DISTRO}/sample_code/edge-data-client/rclnodejs_edge_data_client/
Step4. Run node.js OPCUA sample:
$ node example_SubscribeSensor.js "rclnodejs_OPCUAClient_subscriber" "/adv/opcuaclient"
Step5. Verify received data:
You have entered arguments:
node name: rclnodejs_OPCUAClient_subscriber
message topic: /adv/opcuaclient
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98247999955607
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.396799999928998
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98223999955607
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.372799999928997
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98199999955607
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.348799999928996
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.981759999556076
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.324799999928995
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98151999955608
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.300799999928994
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98127999955608
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.276799999928993
Data: sensor = OPCUAClient/OPCUA-01/Node/Humidity, v = 59.98103999955608
Data: sensor = OPCUAClient/OPCUA-01/Node/Temperature, v = 28.252799999928992
Set sensor
This session describe how to set OPCUA data by set action. To run the set sensor sample, your device need have writable sensor supported for OPCUA driver.
Step2. Setup OPCUAClient Node Message:
Step4. Run OPCUA node set sensor sample:
Command:
node example_SetSensor.js [node name] [action] [sensor] [type] [value]
Example:
$ node example_SetSensor.js "rclnodejs_OPCUAClient_setter" "adv_opcuaclient_set" "OPCUAClient/OPCUA-01/Node/Temperature-SetPoint" "v" 26
Step5. Received data:
[INFO] [1671432195.232498528] [adv.rclnodejs_OPCUAClient_setter]: Waiting for action server...
[INFO] [1671432195.890056725] [adv.rclnodejs_OPCUAClient_setter]: Sending goal request...
[INFO] [1671432196.076197797] [adv.rclnodejs_OPCUAClient_setter]: Goal accepted
[INFO] [1671432196.310811395] [adv.rclnodejs_OPCUAClient_setter]: Received feedback: status = {"status":200,"sensor":"OPCUAClient/OPCUA-01/Node/Temperature-SetPoint","info":"Success","ts":1671432196198}
[INFO] [1671432196.331143326] [adv.rclnodejs_OPCUAClient_setter]: Goal suceeded with result: 202
Python
The program rclpy_edge_data_client is a Python client example for user to understand how to use rclpy to subscribe OPCUA node's data. Please follow below steps to run the program, when the program launched, it will subscribe OPCUA node's sensor and print the data in the console screen.
Subscribe Sensor
Step3. Setup OPCUA sample variables:
$ source /usr/local/Advantech/ros/${ROS_DISTRO}/sample_code/edge-data-client/install/local_setup.bash
Step4. Run Python OPCUA sample:
$ ros2 run rclpy_edge_data_client listener "rclpy_OPCUAClient_subscriber" "/adv/opcuaclient"
node name: rclpy_OPCUAClient_subscriber
C++
The program rclcpp_edge_data_client is a C++ example for user to understand how to use rclcpp to subscribe OPCUA node's data. Please follow below steps to run the program, when the program launched, it will subscribe OPCUA node's sensor and print the data in the console screen.
Subscribe Sensor
Step3. Setup OPCUA node variables:
Step4. Run Python OPCUA sample client:
$ ros2 run rclcpp_edge_data_client listener "rclcpp_OPCUAClient_subscriber" "/adv/opcuaclient"
node name: rclcpp_OPCUAClient_subscriber
