Hardware Preparation
Physical recording requires the Leader, Follower, and cameras to be ready together. Complete this page before recording demonstrations.
Prepare the arms​
  1. Complete installation and check the supported robot and host in System Requirements.
  2. Open Data Tools → Hardware Settings and select the robot model. Follow Arm Platforms & Serial Port Detection to identify the Leader and Follower.
  3. For SO-101, complete the calibration procedure for both arms. For OpenMANIPULATOR-X, follow its procedure in the arm setup guide.
  4. Confirm the connection state before entering physical recording. The hardware FAQ covers connection and calibration problems.
Use the procedure for the selected robot. SO-101 range calibration and the offset alignment used by simulation are different operations; this physical recording route uses the robot's physical setup procedure.
Prepare the cameras​
Follow Camera Setup & Management. A connected camera also needs its enable toggle switched on to be included in recordings.
ViewpointConfirm before recording
WristGripper-object contact and grasp alignment remain visible
TopThe start area, destination, and complete motion remain in view
Fix the camera mounts and use display names that match their positions. A display name helps identify a feed; it does not change the underlying device node. Check the actual image whenever devices are reconnected.
For placement, lighting, and deciding whether a third view is needed, see camera viewpoint design.
Hardware readiness check​
OperationDevices required by the platform
Physical recordingLeader, Follower, and cameras
TrainingA host supported by the selected policy and the saved dataset
Physical inferenceFollower and cameras
Before the first recording, confirm that the platform's readiness check passes, the required images are visible, and the work area is clear. Verify the demonstration setup before starting a batch.
Next: Choose the policy, then continue to Physical Demonstration Recording.
