System & Device Management
Find the guide for maintaining a deployed device. The current topics cover Jetson system images and recovery, plus wireless wake-up for power management.
System images, recovery, and updates
| Your goal | Guide |
| Back up or restore a Jetson system image | Jetson OS Backup & Restore |
| Configure redundant root file systems and verify fallback behavior | RootFS A/B Redundancy |
| Prepare and apply an image-based update | Image-Based OTA Update |
For an update-and-recovery plan, begin with backup and restore, then assess A/B redundancy and OTA for the target BSP. These guides describe separate operations; read the selected guide's platform and version requirements before applying it.
Power management and wake-up
Wake-on-WLAN describes wireless wake-up on AFE-R750 with the EWM-W179 Wi-Fi module, including power checks, driver configuration, hardware routing, and BSP setup.
Use this guide when a robot needs to suspend to save power and wake through Wi-Fi. It is an independent device-management task and does not require following the OTA workflow.
