ASR-D501 for Autonomous Flight Core
This document provides an overview of the demonstrated Advantech Drone Module Solution. Powered by the ASR-D501 (QCS6490) platform, this demo showcases Edge AI Computing, complex sensor fusion, and flight control integration.
Key Features of ASR-D501
The ASR-D501 is a compact, industrial-grade Single Board Computer (SBC) designed as a companion and mission computer for autonomous drones, powered by the Qualcomm QCS6490 SoC.
- High AI Performance at Low Power: Equipped with an 8-core Kryo 670 CPU (up to 2.7 GHz), Adreno 643 GPU, and a dedicated NPU delivering up to 12 TOPS of on-device AI computing—ideal for real-time vision processing and obstacle avoidance without draining the flight battery.
- Extensive Drone Sensor & Vision Connectivity: Features native support for up to 5x MIPI-CSI camera inputs, dual USB Type-C, and high-bandwidth interfaces, allowing direct connection of stereo cameras, MIPI sensors, and LiDAR.
- Ready for Flight Controller Integration: Built-in 2x CAN-FD, 3x UART, and 2x I2C support communication with the flight controller via the MAVLink protocol.
- Optimized Drone & Robotics Software Stack: Supports Ubuntu and Advantech Robotic Suite with compatible ROS 2 and MAVROS/MAVSDK.
- Reliable for Diverse Environments: Supports a wide operating temperature range from -20°C to 70°C, enabling it to maintain stable flight operations under various extreme weather conditions.
Hardware Platform & Components
The physical demonstration unit utilizes the following key hardware components:
- Computing Platform: ASR-D501 (Qualcomm QCS6490)
- Flight Controller: Pixhawk® 6C or CubePilot Cube Orange+
- 3D Camera: Orbbec Gemini 335Lg (USB) or Realsense D457 (USB)
- IMU: Xsens MTi-630 or Xsens MTi-320
- 2D LiDAR: OASAB0649/ OASAB0702
- MIPI Camera: Thundercomm IMX577 Camera Module
Environment Setup
Before running the demo modules, there are a few prerequisite steps to ensure the system environment is properly configured.
1. Configure Swapfile (Recommended)
Setting up a swapfile is highly recommended to prevent out-of-memory (OOM) issues during intensive AI inference tasks or compiling large software packages.
# Allocate a 16GB file for swap space
sudo fallocate -l 16G /swapfile
# Set the correct permissions so only root can read and write (Security requirement)
sudo chmod 600 /swapfile
# Set up the file as a Linux swap area
sudo mkswap /swapfile
# Enable the swap space to start using it immediately
sudo swapon /swapfile
# Add the swap configuration to /etc/fstab to make it permanent across system reboots
echo '/swapfile none swap sw 0 0' | sudo tee -a /etc/fstab
# Verify that the swap space is active and check current memory usage
free -h
2. Install ROS 2 Jazzy
The robotic components and flight control integrations in this project rely on the ROS 2 framework.
Please follow the instructions in the ROS 2 Jazzy Official Documentation ↗ to install ROS 2 Jazzy on your system.
Note: After installation, remember to run the command below in every new terminal before you use ROS 2:
source /opt/ros/jazzy/setup.bash
Demo Modules Overview
The demonstration is divided into six main modules running on the ASR-D501.
1. Downloading Qualcomm AI Hub Models
This module introduces the workflow for preparing optimized AI models specifically tailored for the QCS6490 chipset. It covers the essential concepts of model optimization and quantization to ensure efficient edge AI execution.
We have provided a tutorial on how to utilize Qualcomm AI Hub to deploy optimized models on the ASR-D501.
👉Reference Guide – Downloading Qualcomm AI Hub Models
2. Object Detection on ASR-D501 with MIPI Camera
This module demonstrates real-time visual inspection and edge object detection utilizing an IMX577 MIPI camera directly connected to the ASR-D501. It highlights high-throughput, low-latency vision pipelines suitable for rapid aerial inspection tasks.
We have provided a tutorial on how to run an object detection using IMX577 MIPI camera on the ASR-D501.
👉Reference Guide – Object Detection on ASR-D501 with MIPI Camera
3. Obstacle Avoidance on ASR-D501 with USB camera
This module showcases an autonomous obstacle avoidance pipeline by integrating AI perception with flight control actuation on the ASR-D501. It demonstrates an end-to-end workflow from detecting obstacles to sending reactive avoidance commands to the autopilot.
We have provided a tutorial on how to build an obstacle avoidance pipeline on the ASR-D501.
👉Reference Guide – Obstacle Avoidance on ASR-D501 with USB camera
4. 2D LiDAR Integration on ASR-D501
This module showcases 2D spatial mapping and long-range detection capabilities, providing the system with enhanced environmental awareness for navigation.
We have provided a tutorial on how to integrate and process 2D LiDAR data on the ASR-D501.
👉Reference Guide – 2D LiDAR Integration on ASR-D501
5. Xsens MTi IMU Dashboard on ASR-D501
IMU provides real-time attitude estimation and 9-axis sensor monitoring for flight control stability.
We have provided a tutorial on how to build an IMU Dashboard on the ASR-D501.
👉Reference Guide – Xsens MTi IMU Dashboard on ASR-D501
6. System Monitor on ASR-D501
A UI for tracking system utilization during complex AI computations and multi-sensor processing.
- Monitored Stats: Tracks live metrics such as CPU usage and temperatures across different compute units (CPU, GPU, NPU).
We have provided a tutorial on how to build a system monitor panel on the ASR-D501.
👉Reference Guide – System Monitor on ASR-D501
Next Steps
- 🚀 Deploy Your First Model - Start with Downloading Qualcomm AI Hub Models to export a ready-to-use model, or learn how to quantize and optimize your own models for the QCS6490.
- 📡 Sensor & Flight Integration - Learn how to interface external sensors (IMU, LiDAR, Cameras) and establish MAVLink communication with flight controllers.
- ⚙️ Performance Tuning - Explore QNN profiling and power management settings to balance AI throughput and battery efficiency during flight.
- 🛠️ Hardware Integration & Carrier Design - Consult the ASR-D501 Product Introduction ↗ on the Advantech website for drone integration.
