LLM Edge Deployment and Optimization with llama.cpp
Complete guide for deploying and optimizing Large Language Models on edge AI platforms using llama.cpp.
Use Case​
Application: LLM inference on edge AI devices (NVIDIA Jetson, Intel x86, etc.)
Background:
  • Customer requirement: Improve LLM inference speed on edge platforms
  • Platform:ASR-A702 / NVIDIA Jetson Thor
  • Model: Qwen3.6 via llama.cpp
  • Challenge: Output speed of 46 t/s (tokens per second) affects user experience
Background Analysis​
Why Edge AI for LLM?​
Running LLMs on edge devices offers significant advantages:
Benefits:
  • ✅ Low latency inference (no network round-trip)
  • ✅ Privacy and data security (local processing)
  • ✅ Offline capability (no internet required)
  • ✅ Cost-effective (reduced cloud costs)
  • ✅ Scalability (distributed deployment)
llama.cpp vs Ollama Comparison​
llama.cpp vs Ollama Comparison compare_llama_ollama
💡 Note: This comparison highlights the architectural and performance differences between llama.cpp and Ollama for edge deployment scenarios.
Performance Context​
Tokens Per Second (t/s):
  • Human reading speed: 15-20 t/s
  • Current system: 48 t/s (2× human reading speed)
  • Target: Optimize for better user experience
Edge vs Cloud:
  • Edge device inference ≠ cloud multi-GPU data center
  • Goal: Systematically test how settings affect inference speed
Implementation Steps​
Step 1: Verify GPU Acceleration​
Prerequisites:
  • NVIDIA JetPack SDK installed
  • CUDA acceleration enabled
  • GPU drivers properly configured
Verification:
# Check JetPack version
cat /etc/nv_tegra_release
# Check GPU status
nvidia-smi
# Verify CUDA availability
/usr/local/cuda/bin/nvcc --version
Step 2: Download and Compile llama.cpp​
Requirements:
  • CUDA support enabled
  • CMake build system
  • NVIDIA GPU with compute capability ≥ 7.0
Build Procedure:
# Clone llama.cpp repository
git clone https://github.com/ggml-org/llama.cpp
cd llama.cpp
# Configure with CUDA support
mkdir build && cd build
cmake .. -DLLAMA_CUDA=ON -DCMAKE_CUDA_COMPILER=/usr/local/cuda/bin/nvcc
make -j$(nproc)
Output Binaries:
  • llama-cli: Interactive inference interface
  • llama-bench: Performance benchmarking tool
  • llama-server: HTTP server for API access
Step 3: Download GGUF Model​
Download model from huggingface, we use unsloth/Qwen3.6-35B-A3B-GGUF as example.
download_hugginigface
Step 4: Run Baseline Test (Customer Parameters)​
Baseline Test:
cd llama.cpp
./build/bin/llama-bench \
-m ./Qwen3.6-35B-A3B-MXFP4_MOE.gguf \
-ngl 99 \ # offload all layers to GPU
-fa 1 \ # enable flash attention
-ub 2048 -b 4096 \
-t 12 \ # 12 threads (14 cores available)
--cache-type-k q8_0 --cache-type-v q8_0 \
-p 512,1024,2048,4096,8192,16284,32768 \
-n 128,256,512,1024,2048
Results:
  • Initial throughput: ~48 t/s
  • System runs stably but performance is limited
Baseline Test
Step 5: Thermal Management - Fan at Max Speed​
Action:
  • Set fan speed to 100% maximum
  • Monitor thermal throttling status
Verification:
$ sudo systemctl disable nvfancontrol.service
$ sudo systemctl stop nvfancontrol
$ sudo su //the password is ubuntu
$ echo 0 > /sys/class/hwmon/hwmon2/pwm1
Step 6: Lock to Maximum Performance Mode​
Performance Profile:
# Enable maximum performance mode
sudo nvpmodel -m 0
# Lock CPU and GPU frequencies
sudo jetson_clocks
Performance Mode
Step 7: Run Model Inference (llama-cli)​
Optimized Execution:
./build/bin/llama-cli -m ~/Downloads/Qwen3.6-35B-A3B-MXFP4_MOE.gguf \
-ngl 99 \
-fa 1 \
-ub 2048 \
-b 4096 \
-t 12 \
-n 512 \
-p "what's up"
Results:
  • Baseline: ~48 t/s (with thermal throttling)
  • After performance mode: ~52 t/s (8% gain)
Performance Comparison
Step 8: Launch Web UI (llama-server)​
Server Setup:
./build/bin/llama-server \
-ngl 99 \
-fa 1 \
-ub 2048 \
-b 4096 \
-t 12 \
--cache-type-k q8_0 \
--ctx-size 8192 \
--host 0.0.0.0 \
--port 8080
Access from browser
http://localhost:8080
Web UI
Conclusion​
Key Findings​
Baseline Reproduced:
  • ✅ ~48 t/s confirmed
  • ✅ At 2× human reading speed, this is not a user-experience problem on edge device
Hardware Configuration:
  • ✅ Fan at 100% + MAX power mode (nvpmodel -m 0) + locked clocks (jetson_clocks)
  • ✅ Throughput: 52 t/s — an 8% gain over baseline
Recommendations​
  1. Thermal Management is Critical
    • Ensure adequate cooling for sustained performance
    • Use maximum fan speed during inference
    • Monitor thermal throttling indicators
  2. Performance Mode Lock
    • Always use nvpmodel -m 0 for maximum performance
    • Apply jetson_clocks to lock frequencies
References​
← Back to Solution Overview
